engr
How to use columnlist to stack a lot of columns
Hi all, I want to read out the column names and save them as a column list .... using this list can I stack these multiple columns in a single command instead of manual stacking like the code shown below ?
dt_L5 << Stack(
    columns(
        :Name( "MISC_L5_Test230_2(1)" ),
        :Name( "MISC_L5_Test230_2(2)" ),
        :Name( "MISC_L5_Test230_2(3)" ),
        :Name( "MISC_L5_Test230_2(4)" ),
        :Name( "MISC_L5_Test230_2(5)" ),
        :Name( "MISC_L5_Test230_2(6)" ),
        :Name( "MISC_L5_Test230_2(7)" ),
        :Name( "MISC_L5_Test230_2(8)" ),
       :Name( "MISC_L5_Test230_2(125)" )
    Source Label Column( "Label" ),
    Stacked Data Column( "Data" ),
    Output Table( "L5" )
I want to do some thing like this :
clist=dt_L5<<Get Column Names;
ncols = N Items(clist);
dt_L5 << Stack(
    columns(
     for(i=1,i<=ncols,i++,
         name_list = clist;
         /* HOW SHOULD I CALL THE ":Name("name_list") " here ?? */
ms
Super User (Alumni) ms
Either contitionally like this:
tlist={};
    if(i>3,
        insertinto(tlist,collist[i]);
or without condition but a modified initial i:
tlist={};
for(i=4,i<=ncols,i++,
9 REPLIES 9
ms
Re: How to use columnlist to stack a lot of columns
Stack takes a list as argument so it's can be done in much simpler way here.
collist = dt1_L5 << get column names;
dt1_L0 << stack(
          columns( (collist) ),
Avoid for-loops inside platform commands. Btw, I tried to submit a reply to your previous question, but it had been deleted before I hit "Add Reply". Probably you found a solution already, but here's my take on that. Again, for-loops inside platforms may not always work as some commands may not evaluate the argument (e.g a quoted string is required).
monthlist = {4, 5, 7, 9, 11, 12};
wind = New Window( "Bivariate",
          dt1_L0 << Bivariate( Y( :Data ), X( :Price ), By( :MONTH ) )
For( i = 1, i <= N Items( monthlist ), i++,
          wind[1, i, Framebox( 1 )] << {Frame Size( 633, 249 ),
           Row Legend(:FLOORS,
                    Color Theme( "JMP Default" ),
                    Marker Theme( "Standard" ),
engr
Hi MS,
Thanks for the quick reply. I'm a newbie to JSL so I dont know my way across the language. Good to know that stack accepts list as an argument.
Can I expand the question further and ask ... how can we select only a few columns to be stacked from the list ? For example, I dont want to stack the first 3 columns. For this purpose, can I make a new list which will store the required column names (drops the first 3 column names from the collist) .
Yeah, I figured out a solution to my previous entry so I deleted it
Thanks so much!
engr
Something like this ?? ....
/*Intent here is to save a new list by dropping the first 3 from the prev list*/
ncols = N Items(collist);
for(i=1;i<=ncols;i++,
    if(i>3,
        tlist=collist;
dt1_L0 << stack(
          columns( (tlist) ),
I dont even know if the "if" statement is correct here ... please excuse my ignorance
ms
tlist={};
    if(i>3,
tlist={};
engr
Thanks once again! ... After the stack command I get the following message in log window
"Column not found in access or evaluation of 'Bad Argument'
Empty()"
And I do not see any stacked table output ... :-s I really appreciate your help!
engr
a search on this forum directed me to the answer ..... eval(list) has to be used.
dt1_L0 << stack(
          columns( eval(collist) ),
Thank you for your support!
ms
Ok. For me it also works without eval(). JMP 9.0.3 for Mac.
This even works, i.e creating the list inside the columns()-argument. Can be convenient if you do not need the parameter later in the script. However, clearly stating variables makes the code easier to read and debug.
dt1_L0 << stack(
          columns( dt1_L0 << get column names ),
engr
Great! Thanks MS ... I have JMP8.0 maybe that's the problem
dabiziv
does your final script looks something like this?
Clear Globals (); /* clears resident memory from previous runs*/
/* Open your file*/
dt=open(
     Pick File(
          "Select a *.csv file",
          Get Current Directory(),
          {"All JMP Files|jmp;jsl;jrn;csv;txt", "All Files|*"}
wait(0);
nc_dt = N Col (); /*gets number of columns in a file*/
wait(0);
clist = dt <<Get Column Names; /* gets colum names to be used in stacking*/
wait(0);
tlist={};
for(i=2,i<=ncols,i++,
    insertinto(tlist,clist);
wait(0);
dt2 << Stack(
    columns(eval(tlist)),
    Output Table( "DT5" )
