Kirk_A
How to use Radio Boxes
I am brand new to JMP scripting and trying to self teach. I created a radio box:
New Window( "Example",
panelbox("Confidence Interval",
rb = Radio Box(
{"90%", "95%", "98%", "99%"},
Show( rb << Get() ),
My current question is how can I use the variable rb?
I tried this if(then) statement:
If(
	:rb == "95%",
// then
	:x = 1.96,
	:rb == "90%", :x = 1.645,
	:rb == "98%", :x = 2.326,
	:rb == "99%", :x = 2.576,
but get this error message: "Name Unresolved: rb in access or evaluation of 'rb' , :rb/*###*/"
Here is the whole code.
computeResults = Expr(
	If(
		:rb == "95%",
// then
		:x = 1.96,
	Panel Box( "Confidence Interval",
		rb = Radio Box(
	H Center Box( Button Box( "Calculate Minimum Sample Size", computeResults ) ),
	V List Box( Text Box( "" ), ciolb = Panel Box( "Result", x = Number Edit Box( "" ) ) )
Thanks for any help or suggestions. I'll be reading the scripting manual and check back later.
12 REPLIES 12
Kirk_A
Re: How to use Radio Boxes
I think I have an understanding of what is going on. Hopefully LAST question.
If I set a variable say x = 3 it looks like I can "reset" x later to say x = z+ y without an error (syntax error at least). Am I correct?
You can do that. But in your case, since x is use in your display window, you need to understand that x will no longer point to the numbereditbox
Kirk_A
Yep, I see that. I just wanted to verify the theory. Thanks again.
