cyrus_cheung
How to use JSL for Fit Group with by column?
Not sure what is erroring out in this script using Fit Group in JSL. It still plots the graph as I wanted, however it terminated the script at that point.
In the following script, error marked by /*###*/
Fit Group(
	Bivariate(Y(:A), X(:AAA),
	Bivariate(Y(:A), X(:BBB)),
	Bivariate(Y(:A), X(:CCC)),
	Bivariate(Y(:B), X(:AAA)),
	Bivariate(Y(:B), X(:BBB)),
	Bivariate(Y(:B), X(:CCC)),
	<<{Arrange in Rows(3)},
	By(:Group123) /*###*/
Re: How to use JSL for Fit Group with by column?
I assume the issue is that the By needs to be associated with each of the separate Bivariate instances
Fit Group(
	Bivariate(Y(:A), X(:AAA),By(:Group123)),
	Bivariate(Y(:A), X(:BBB),By(:Group123)),
	Bivariate(Y(:A), X(:CCC),By(:Group123)),
	Bivariate(Y(:B), X(:AAA),By(:Group123)),
	Bivariate(Y(:B), X(:BBB),By(:Group123)),
	Bivariate(Y(:B), X(:CCC),By(:Group123)),
Fit Group(
cyrus_cheung
Thanks!
