qspringleaf
How to use JMP script to generate a table with duplicate data
How to use JMP script to generate a table with duplicate data, list below...
kindly su
Before   After
NameShift   NameShift
JohnShiftA------>'JohnShiftA
KevinShiftB   KevinShiftB
TomShiftC   TomShiftC
TimShiftD   TimShiftD
LilyShiftE   LilyShiftE
JessicaShiftF   JessicaShiftF
     JohnShiftA
     KevinShiftB
     TomShiftC
     TimShiftD
     LilyShiftE
     JessicaShiftF
     JohnShiftA
     KevinShiftB
     TomShiftC
     TimShiftD
     LilyShiftE
     JessicaShiftF
     JohnShiftA
     KevinShiftB
     TomShiftC
     TimShiftD
     LilyShiftE
     JessicaShiftF
     JohnShiftA
     KevinShiftB
     TomShiftC
     TimShiftD
     LilyShiftE
     JessicaShiftF
tom_abramov
Level V
Re: How to use JMP script to generate a table with duplicate data
Try this:
dt = Current Data Table();
Ntimes = 5;
for(i=1,i<=Ntimes,i++,
	dt << Concatenate (dt, Append to first table(1));
Craige_Hales
Nice! if you want N copies rather than doubling the size N times, you can start with an empty table like this:
Ntimes = 5;
dtnew = New Table();
For( i = 1, i <= Ntimes, i++,
	dtnew << Concatenate( dt, Append to first table( 1 ) )
The empty table is special when first created: it appears to have a column named "Column 1", but that column is a placeholder that will vanish if not used.
Doubling with Tom's answer is much faster if you need a lot of copies. 10 doubles in 0.02 sec or 1024 copies in 0.50 sec.
 @chungwei
Craige
tom_abramov
Level V
Try this:
Ntimes = 5;
Craige_Hales
Ntimes = 5;
 @chungwei
Craige
