Danial
How to use 'IF' statements to delete the entire 'Row'?
How to delete the entire 'Row' when the cell is blank/empty ?
3 ACCEPTED SOLUTIONS
Re: How to use 'IF' statements to delete the entire 'Row'?
There is no need to use an IF() clause in the deleting of the rows with missing values.
// If checking for a character column
dt << delete rows(dt<<get rows where(:link==""));
// If checking for a numeric column
dt << delete rows(dt<<get rows where(isMissing(:Quantity)));
JLX
JLX
YEAH, I agree with @txnelson , if you really wanna do this by using if, you can do like below
dt = Open( "$sample_data/big class.jmp" );
total_rows = N Row( dt );
For( i = total_rows, i >= 1, i--,
	If( :age[i] == 14,
		dt << delete rows( i );
		wait(0.5) // wait for a while to let you see the delete action
ThuongLe
or you can do this:
dt << Select Where(Is Missing(:column_you_want_to_check));
dt << Delete Rows;
Thuong Le
Danial
This is an example of the a data table to my problem Operation Product Link Quantity 1 A ABC 1000 1 A ABC 3000 1 A 1350 1 A 1235
JLX
JLX
	If( :age[i] == 14,
Danial
Thank you so much. Thanks for clearing things up
ThuongLe
or you can do this:
dt << Delete Rows;
Thuong Le
