Neo
Neo
How to start Multiple File Import () vis JSL with Keep Dialog Open unchecked?
As the tile says - I have tried the following but does not work
// use the save-script-to-script-window button
// in the MFI dialog to see more messages
// for filtering files and controlling the import
Multiple File Import( Keep Dialog Open (0),
	<<Set Folder( "$DESKTOP" ),
	<<Set Name Filter( "*.csv;" ),
	<<Set Name Enable( 1 )
) << Create Window;
Where am I going wrong?
When it's too good to be true, it's neither
Re: How to start Multiple File Import () vis JSL with Keep Dialog Open unchecked?
Slight modification is needed (and is better for JMP17 also) as JMP17 has different default value change << Set to << Set All
mfi = Multiple File Import(
	<<Set Folder("$DESKTOP"),
	<<Set Name Filter("*.csv;"),
	<<Set Name Enable(1)
) << Create Window;
// Check box with text box saying 'Keep dialog open' is last checkbox
checkboxes = (mfi << XPath("//CheckBoxBox"));
checkboxes[N Items(checkboxes)] << Set All(0);
17 REPLIES 17
You could navigate to the check box and control it that way
) << Create Window;
checkboxes[N Items(checkboxes)] << Set(0);
Neo
Neo
@jthi  Thanks but does not work in JMP 16.2.0 (on Windows 10)
) << Create Window;
Neo
Neo
@jthi  Your code works for me but I have a connected problem. It appears that the code proceeds without the user pressing the import button.   In my case (JMP 16.2 on Win10), the window tilte is shown and the journal window pops up. How to hold progress until the user has pressed the import button.
) << Create Window;
mfi<< Get Window Title(); show (mfi);
jrnW  = New Window( "Report", << journal);
You might be able to get Multiple File Import inside modal window somehow or you could try using << On Close
w = mfi << Create Window;
w << on close(
checkboxes = (w << XPath("//CheckBoxBox"));
Neo
Neo
@jthi . Thanks. On Close only appear to work in case of the journal window. Does not work for the following for example.
w << on close(
I need a run a large script after the user selects the files using the Multiple File Import function. The script operates on the selected files. Could I please have the example with  Multiple File Import function inside a Modal Window? In this case, how to reference he files opened by Multiple File Import  (in my case two files) for further use?
Most likely it won't work in your case as the mfi has been closed. I would go with On Close route because modal window will most likely mess up the buttons of Multiple File Import
aa_olddt = Associative Array(Get Data Table List() << get name);
	<<Set Folder("$SAMPLE_DATA"),
w = mfi << Create Window();
w << On Close(
	aa_newdt = Associative Array(Get Data Table List() << get name);
	aa_newdt << Remove(aa_olddt);
	dt_list = aa_newdt << get keys;
	Caption(dt_list);
Neo
Neo
@jthi Thanks, but how does one call further scripts (e.g to plot etc) to operate on the data tables imported. The first one below works, but this is not what I need.
//clear log ();
	<<Set Name Filter("Big*"),
w << On Close(
	show (dt_list);
	dt = dt_list[1];
	dt = data table (dt);
	dt<<Distribution( Column( :Age, :Weight ) );
	//include ("plotDist.jsl");
I need to be able to call scripts to operate on the imported data files. One below does not work (gives attached error)
//clear log ();
w << On Close(
	show (dt_list);
	dt = dt_list[1];
	//dt<<Distribution( Column( :Age, :Weight ) );
where plotDist.jsl (saved in the same directory) is
Putting
outside On Close also does not work. Where am I going wrong?
Names (strings) of datatables are stored to dt_list so you have to convert them to data table references when using.
//clear log ();
w << On Close(
	Datatable(dt_list[1]) << Distribution(Column(:Age, :Weight));
Depending on your application it might be a good idea to loop over the dt_list (maybe rename it to dtname_list) and create a list of datatable references
