LBrian
How to setup Combo box list?
Hello.
I wanna make a list using combo box, showing ".csv" only.
How to setup the list?
In my code,
All files are listed up on selected directory.
Load file = New Window( "New Window",
	<<modal(),
	<<ReturnResult,
	<<on close(
	H List Box(
		Text Box( "Choose directory" ),
		Spacer Box( size( 10, 10 ) ),
		BB1 = Button Box( "Load file",
			address1 = Pick Directory();
			If( address1 == "",
				file1 << set text( "" ), //else if
				If( address1 != "",
					file1 << set text( address1 )
	Panel Box( "",
		V List Box( Text Box( "Directory path :" ), Spacer Box( size( 300, 10 ) ), file1 = Text Box( "" ) )
path = address1;
address1 = Files In Directory( address1 );
nw = New Window( "Pick CSV Files",
	Panel Box( "List",
		Lineup Box( N Col( 2 ),
			Text Box( "1st:" ),
			cb1 = Combo Box( address1 ),
			Button Box( "OK" );
Re: How to setup Combo box list?
All you need to do is to loop backwards through the address1 list and remove all of the entries that are not .csv files.
For( i = N Items( address1 ), i >= 1, i--,
	If( Word( -1, address1[i], "." ) != "csv",
		Remove From( address1, i, 1 )
See the Scripting Index for definition and examples of any of the above used functions.
LBrian
It works very well!
Thank you so much.
Also if you have JMP16+, you can use Filter Each
address2 = Filter Each({filename}, Files In Directory(address1),
	Ends With(filename, ".csv");
