How to set the name of a text box as a variable?
I want the new window to have a few tabs on each tab that will have a text box from which I get a value for the corresponding tab.
Currently in the program I wrote all the text boxes of the same name and therefore the value is obtained from the text box in the last tab.
How do I define the name of the text box as a variable?
This is the code I wrote -
Chart_func = function( {Layer},
vlistbox(Outline Box(Layer),
H List Box( Text Box( "enter NEW CL: " ), theBinNumber = Number Edit Box() ),
Button Box( "OK", NEW_CL = theBinNumber << get)
MTK72Mon_TAB = Tab Box(
	"  TIN_LD  ", Chart_func("TIN_LD"),
	"  TIN_HD  ", Chart_func("TIN_HD"),
	"  CU 225A  ", Chart_func("CU_225A"),
MTK72_Mon_charts = new window ("MTK72 Mon",hlistbox("Title"),	MTK72Mon_TAB);
Re: How to set the name of a text box as a variable?
You need to provide a unique pointer to each of the elements in each of the Tab Boxes.  Below is one way to do that
counter = 0;
counter++;
eval(Substitute(
		Expr(
			V List Box(
				Outline Box( Layer ),
				H List Box( Text Box( "enter NEW CL: " ), __theBinNumber__ = Number Edit Box() ),
				Button Box( "OK", __NEW_CL__ = __theBinNumber__ << get )
	Expr( __theBinNumber__ ), Parse( "theBinNumber" || Char( counter ) ),
	Expr( __NEW_CL__ ), Parse( "NEW_CL" || Char( counter ) )
counter = 0;
counter++;
eval(Substitute(
		Expr(
			V List Box(
Thank you very much, you really helped me!!!
