Saravana
How to set Axis Labels for Graph box in JMP application?
Hi all,
I am using JMP application for plotting a test result. I am using the below script lines to set values to the graph,
Results1 << Set Title ("WFM");
Result Graph << Set X Axis ({Min(0), Max(Res_x_max), Format("Best", 9)});
Result Graph << Set Y Axis ({Min(Res_y_max), Max(Res_y_min), Format("Best", 9)});
Result Graph << Set Graphics Script (Marker (Res_x,Res_y));
My problem is I want to update the X and Y axis labels whenever I launch the the module. I don't know how to set axis labels and its orientation. Please help me with this
cwillden
Re: How to set Axis Labels for Graph box in JMP application?
Hi @Saravana,
Is the graph a custom graphbox?  I'm guessing you want to do something like use the name of a column that the user specifies in the dialog as an axis label.  You can set the axis names using something like this:
X_label = "X Variable";
GB << Set X Name(X_label);
I'm sure there's a way to orient the label text using Rotate Text("Right"|"Left"|"Horizontal") somehow, but I wasn't able to get anything from the Scripting Index on that.  I tried a few things, but nothing worked.
-- Cameron Willden
