    Regular business hours will resume at 9:00 a.m. ET on Friday, Jan. 2, 2026.
mhafiz
How to select patterns based on segments of strings
I'm a new user of JSL. In order to group a large number of  pins and adding a new columns for those groups, I'm thinking to use JSL. I got to know how to do that for first consecutive characters (e.g. for DDR0CH0CKN... I know how to filter it using DDR0...) but if I'm to do that using segments like 'DDR0' and 'CK', what would be an efficient way to do that?
FYI: One way, I know, is to use a manually created file and then use update command to match pins to pin groups (not an efficient way). I tried patMatch/regex etc. but could not get the desired result.
For your convenience, I've attached .jmp file where I want to have a column called "Desired_Pin_Group" for the pins.
I appreciate your cooperation.
Regards,
Hafiz.
Re: How to select patterns based on segments of strings
Here is a script that will do what you want, given the example you gave.  If you have a lot more pin combinations that require exception processing this may not be the best way to handle this.
dt = Current Data Table();
dt << New Column( "Generated Pin Group", character );
For Each Row(
// Get the first part of the group name
	First = Lowercase( Substr( :Pin, 1, 4 ) );
// Handle exceptions like the below case
	If( First == "ddrr",
		First = "ddr0"
// Now attach the "_"
	First = First || "_";
// Now add the second part based upon the given complexities
	// Handle the clk
	If(
		Contains( :Pin, "_CK" ) > 0 & Contains( :Pin, "_CKE" ) == 0, First = First || "clk",
	// Handle the vref
		Contains( :Pin, "_VREF" ) > 0, First = First || "vref",
	// Handle the cke
		Contains( :Pin, "_CKE" ) > 0, First = First || "cke",
	// Handle the reset
		Contains( :Pin, "RESET" ) > 0, First = First || "Reset"
	:Generated Pin Group = First;
If you want to do this as a formula for a column, it is just a simple change
	First = "ddr0"
If(
First;
For Each Row(
		First = "ddr0"
	// Handle the clk
	If(
	// Handle the vref
	// Handle the cke
	// Handle the reset
	First = "ddr0"
If(
First;
mhafiz
Thanks for your quick response. The script is quite ok for the .jmp file that I gave previously. But, unfortunately it's not that straightforward. The number of pins is in the range of 150-200 and those are grouped within 15-20 groups. Please have a look at the newly attached .jmp file, it's closer to the real scenario. Just have a look from 22-27 and 81-83. Those 2 groups have DDR_Y in common, but they are filtered based on other phrases within the string. The logic is something like: if :Pin=='DDR_Y' && Pin != NC :Desired_Pin_Group=ddr_dq_ch0 else :Desired_Pin_Group=ddr_ctrl. The distinguishing criteria between the groups (81-83) and (93-96) are even more complex. One needs to search the last phrases.
Your cooperation is highly appreciated.
Hafiz.
JMP provides an entire pattern matching suite of functions and constructs that you might find useful here. See Help > Books > Scripting Guide. Then search for this section in the book.
mhafiz
Hi txnelson,
I used the concept of the conditional statement that you provided and could solve my issue. Rather than converting to lowercase, I added a new column in the table and put the pin name directly using parenthesis, as:
dt <<New Column("Match_Pin_Grp", Character, Nominal,
Formula(
If(Contains(:Pin, "_CK")>0 & Contains(:Pin,"DDR0") & Contains(:Pin, "_CKE")==0,"ddr0_clk",
Contains(:Pin, "_CK")>0 & Contains(:Pin,"DDR1") & Contains(:Pin, "_CKE")==0,"ddr1_clk",
However, I'm accepting it as a solution to the problem.
Thanks for your help.
Regards,
Hafiz.
Hafiz,
I am happy that I have been able to help you solve your problem.
