septon
How to select individual cell based on condition and insert it?
Hello
I am trying to select an individual cell based on condition and insert it to a column in JSL.
For example:
I have this following table - I want to insert to the first row under column "value"  the "score" value of the second row (11) because:
when looking on the first and second row:
home = home and y=y and x=x+1
Input:
scorehomeyxvalue
10US11
11US12
10Canada11
10US35
Expected:
scorehomeyxvalue
10US1111
11US12
12Canada11
13US35
Thanks
Re: How to select individual cell based on condition and insert it?
Most likely this isn't exactly what you want, but it does solve your example
dt = New Table("Untitled",
	Add Rows(4),
	Compress File When Saved(1),
	New Column("score", Numeric, "Continuous", Format("Best", 12), Set Values([10, 11, 10, 10])),
	New Column("home", Character(16), "Nominal", Set Values({"US", "US", "Canada", "US"})),
	New Column("y", Numeric, "Continuous", Format("Best", 12), Set Values([1, 1, 1, 3])),
	New Column("x", Numeric, "Continuous", Format("Best", 12), Set Values([1, 2, 1, 5])),
	New Column("value", Numeric, "Nominal", Format("", 16), Set Values([., ., ., .]))
Row() = 1;
If(:home == Lag(:home, -1) & :y == Lag(:y, -1) & :x + 1 == Lag(:x, - 1),
	:value[Row()] = Lag(:score, - 1)
