FestacFarmer
How to select an active tabulate window to make into data table
Hi All;
I am trying to script the "Make Into Data Table" functionality into a toolbar icon (for quicker access and shortcut capability).
However, I am unsure how to select an active "tabulate" window to apply the function to. I assumed doing something like in the image below should work but I have been unable to, unfortunately.
There should be an easy solution but I have not been able to find it!
Thank you
ErraticAttack
Re: How to select an active tabulate window to make into data table
Yes, it is easily done!
Here is the code to put into the menu-item
win = Current Window();
Try(
    obj = ( win[Outline Box( 1 )] << Get Scriptable Object );
    If( Char( obj ) == "Tabulate[]",
        obj << Make into Data Table
Jordan
ErraticAttack
Try(
Jordan
FestacFarmer
Thank you! This worked perfectly
