sgpt
How to save webpages through JSL
How can I save webpages from JSL? I use the following lines of code to open the webpage in a JSL
url = "https://www.nytimes.com";
w = New Window( "s1",wb = Web Browser Box(url ), wb << Set Size( 1200, 1200 ););
w << Set Window Size( 1200, 1200 );
Thereon, what can I do to save the webpage with full graphics in a form that can be consumed later (pdf or full graphic html)? I essentially need to do this for a few hundred internal URLs for a database for visualization that is being turned off.
10 REPLIES 10
Jeff_Perkinson
Re: How to save webpages through JSL
You may be able to use Run Program() to launch Python to accomplish this in JMP 12. There's a good paper from Discovery Summit Europe 2016 with good examples for how to use Run Program.
However, JMP 14 is a complimentary upgrade for users with an Annual License. You should speak to your license administrator about getting JMP 14. If you don't know who that is send me a private message and I'll be able to assist you.
-Jeff
