Georg
How to run program with whitespaces in path
Dear community,
I want to zip files in current directory on win10 with JMP,
so I use run program() and cmd or powershell.
But with onedrive there are whitspaces in my path, how can I get it working?
Have found: https://community.jmp.com/t5/Discussions/Open-file-in-excel-with-whitespace-in-filename/m-p/911999?s... in usergroup, but didn't help me.
Thanks!
base_path = Get Default Directory(); // doesn't work
base_path = "C:\Users\"; // works
Show( base_path );
// e.g. base_path = "/C:/Users/user/OneDrive - Documents/";
// how to mask space in path??
command = Eval Insert( "dir ^base_path^" );
// command = eval insert("\[dir "^base_path^"]\"); // doesn't work
Show( command );
RP = Run Program(
	Executable( "cmd.exe" ),
	Options( Insert( {"/a", "/q", "/c"}, command ) ),
//	ReadFunction( Function( {this}, Write( this << read ) ) )
	readfunction( "Text" )
Georg
3 ACCEPTED SOLUTIONS
Re: How to run program with whitespaces in path
Adding quotes around the path should work
base_path = "C:\Program Files\"; // works
Show(base_path);
command = Eval Insert("dir \!"^base_path^\!"");
Show(command);
RP = Run Program(
	Executable("cmd.exe"),
	Options(Insert({"/a", "/q", "/c"}, command)),
	readfunction("Text")
Georg
Hi Jarmo, thanks, your're right, I had a problem with the starting backslash as well.
// starting backslash makes problems, needs to be removed
// "/C:/Users/<user>/OneDrive - Documents/"
base_path = Substr( base_path, 2, Length( base_path ) );
command = Eval Insert( "dir \!"^base_path^\!"" );
Show( command );
RP = Run Program(
Georg
I would use Convert File Path() with "windows" argument to remove the first backslash
base_path_w = Convert File Path(base_path, "windows"); // "C:\Users\<USERNAME>\Documents\"
Show(base_path);
Show(command);
RP = Run Program(
Georg
Show( command );
RP = Run Program(
Georg
