user8421
How to repeat values in a column when they are strings
Hi everyone!
I've used this script below for numerical values
If( Is Missing( :Name( "For Calc - Data1" ) ),
	Lag( :Name( "Data1" ), 1 ),
With the resulting table looking like this
For Calc - Data1 Data1
12 12
  12
  12
33 33
  33
However I can't apply this same formula to a column that has strings or characters to result in the following data table because I get an error saying that the value must be Numeric.
For Calc - Data2 Data2
A A
  A
  A
B B
  B
Is there a workaround or an alternative formula I can use to achieve this?
Re: How to repeat values in a column when they are strings
Here is the method I use
If( Row() == 1,
	x = :"For Calc - Data2"n
If( As Column( "For Calc - Data2" ) != "",
x;
