agonzales2021
How to rename the outline box default to "graph builder"
How do I rename the outline box on a graph builder that by default says "Graph Builder"
Re: How to rename the outline box default to "graph builder"
See Help > Scripting Index. Change the drop-down menu in the upper left corner to Display Box. Select Outline Box in the left-most list. Now you see the entire protocol for this class. Look for the Set... message that you need.
agonzales2021
I have tried this already and it isn't working
ian_jmp
Level X
Using JSL, and as Mark said:
NamesDefaultToHere(1);
gb = dt << Graph Builder(Variables( X( :weight ), Y( :height ) ));
Wait(2);
Report(gb)[OutlineBox(1)] << setTitle("New Title");
ian_jmp
Level X
If you are doing it interactively, you can just double click and type in the new name.
pmroz
After doing what Ian suggests you can look at the JSL code to see how JMP did it.  In Graph Builder click the red triangle and select Script > Copy Script.  Paste the script into a new JSL window and you'll see something like this (I added the open of big class):
dt = open("$sample_data\Big Class.jmp");
Graph Builder(
	Size( 526, 451 ),
	Show Control Panel( 0 ),
	Variables( X( :weight ), Y( :height ) ),
	Elements( Points( X, Y, Legend( 16 ) ), Line( X, Y, Legend( 18 ) ) ),
		Dispatch( {}, "Graph Builder",
			OutlineBox, {Set Title( "This is my graph" )}
