spoikayil
How to refer to the datatable from which script was done?
This might be a stupid question, but how do I refer to the datatable from which I ran the script if I dont know what the table name it is save as before hand?
In most solutions in the forum the script starts with something as:
and then you can do things to dt like
dt << NewColumn( - - - -
But what if I want my script to just run asuming dt is whatever table from which the script was run?
ih
Super User (Alumni) ih
Re: How to refer to the datatable from which script was done?
If you are sure it will run against the table that was active when the script is started you can use the current data table:
dt = current data table();
