miguello
How to refer to a column in Group By() message in Bivariate Platform
I have a Bivariate Platform scripted like this:
Fit Group(
	biv = Bivariate( Y(Eval(Y_parameters)), X(Eval(X_parameters)), Group By (groupByColumn[1]),
			SendToReport(...)
where
Y_Parameters = {"Param1", "Param2"};
X_Parameters = {"Radius"};
groupByColumn = {"Lot ID"};
So, it works ONLY if my groupByColumn is a list of strings, and only if I refer to it as groupByColumn[1]
if I say
stringGroupByColumn = groupByColumn[1]
and then use
Group By (stringGroupByColumn)
it won't work.
WHY?
If I say
groupByColumn = "Lot ID";
and then use it - it also won't work. WHY?
Re: How to refer to a column in Group By() message in Bivariate Platform
The reason it does not work is because you are not setting a variable value, but rather you are passing a message to thr Bivariate Platform.  The proper syntax is
Biv << Group By( :lot ID );
See the Scripting Index for examples
miguello
Ok, what if I don't know the column name and I just picked it from Col List Box?
When I get columns from Col List Box using << Get Items it returns them as:
in case of the Col List Box that I use to cast Group By it only returns one due to the settings of Col List Box, it returns it as this:
groupByColumn = {"SomeRandomColumn"};
the only way to use it is
miguello
Ok, looks like it works this way:
 Y_parameters = colListYParameter << Get Items;
X_parameters = colListXParameter << Get Items;
groupByColumnNames = colListBox << Get Items;
groupByColumn = Column(groupByColumnNames [1]);
biv = Bivariate( Y(Eval(Y_parameters)), X(Eval(X_parameters)),Group By (groupByColumn), Fit Spline( 0.1, Standardized),
			SendToReport(...)
Basically, I wanted to use "clean" variable, that is just a reference to column, without it being a subscript of a string array.
