kaushik_pushpen
How to put variable title name in the list of graph?
Hello all,
I am not able to find problem why it is not showing title name according to the variable "a1". Please find my script below.
dt1 = open("F:\pushpendra\jmp\HIPO_RintCalculation.jmp");
dt2 = open("F:\pushpendra\jmp\wafer.jmp");
for(i=1,i<=nrow(dt2),i++,
  a1= Eval(column(dt2, 1));
  biv=dt1<<Bivariate(
  Y( :Site_Value ),
  X( :Name( "Length(um)" ) ),
  Fit Line( {Line Color( "Red" )} ),
  where( :Wafer == a1 ),
  se2=(biv<<report)<<outlinebox<<Set Title("wafer No=" || a1);
Please find the problem and help me. Thanks in advance.
ian_jmp
Level X
Re: How to put variable title name in the list of graph?
There are a few possibilities, and you didn't quote an error message. The code below may give you some idea as to how to fix it:
biv = dt << Bivariate(X(:height), Y(:weight));
for(i=1, i<=5, i++,
Report(biv)[OutlineBox(1)] << SetTitle("Wafer "||Char(i));
Wait(1);
pmroz
Here's a brute force way using eval(parse()).  Note that I'm setting the outlinebox title directly in the code for the bivariate platform.
sex_list = {"F", "M"};
for (i = 1, i <= nitems(sex_list), i++,
      one_sex = sex_list[i];
      biv_expr = evalinsert("\[
      dt << Bivariate(
            Y( :height ),
            X( :weight ),
            Where( :sex == "^one_sex^" ),
            SendToReport( Dispatch( {},
                        "Bivariate Fit of height By weight",
                        OutlineBox,
                        {Set Title( "Sex ^one_sex^" )}
      eval(parse(biv_expr));
kaushik_pushpen
Thank you PMroz​ for the suggestion.
kaushik_pushpen
Thank you very much Ian@JMP​. It is working fine now.
