How to provide column names manually in script for importing multiple text files?
I was able to use the import multiple files tool to get a Skelton script. I would like to add column names to created table through the script. Is there a way to do that?
Re: How to provide column names manually in script for importing multiple text files?
You could for example have a list of column names and then loop over that list while setting the names. Depending where you get the names how you might want to loop might be different
dt = New Table("Untitled",
	Add Rows(0),
	Compress File When Saved(1),
	New Column("Column 1", Numeric, "Continuous", Format("Best", 12), Set Values([])),
	New Column("Column 2", Numeric, "Continuous", Format("Best", 12), Set Values([])),
	New Column("Column 3", Numeric, "Continuous", Format("Best", 12), Set Values([])),
	New Column("Column 4", Numeric, "Continuous", Format("Best", 12), Set Values([]))
mycols = {"a", "b", "c", "d"};
wait(1); // for demo purposes
For Each({colname, idx}, dt << Get Column Names("String"),
	Column(dt, colname) << Set Name(mycols[idx]);
You might also be already add the names in the import script but it might depend on your file
