WebDesignesCrow
How to pin cross-hair onGraph Builder?
Hello expert.
I'm using JMP 17.2 cross-hair feature.
It's a very good tool.
But, is there any way to lock/pin the cross-hair on the graph builder (I want to find two X-axis values associated to 1 Y-axis value)?
The cross-hair value disappear after I release the mouse "click".
This is an impromptu analysis so I'm not using JSL scripting.
Thank you.
Re: How to pin cross-hair onGraph Builder?
I don't know your use case, but you can "pin" crosshair (or ruler) once to your graph, at least on Windows. Create crosshair on your graph, right click and then left click on the window title
Edit: wish list itemAllow pinning/locking crosshairs and rulers to graphs
(view in My Videos)
(view in My Videos)
WebDesignesCrow
Thanks @jthi .
Actually, I want to pin 2 cross-hair lines to get the X-axis values that follows the smoother line at 0.5Max.
I guess, it's not possible for time being.
I also need to jot down the value manually to continue the analysis in Excel.
It would be great if the values can be combined with the JMP data table so that I can finish the analysis with JMP rather than going back to Excel.
Thank you for put up the wish list. I support 100% !.
Just noticed that it seems quite many wish lists related to this cross-hair tool for Graph Builder.
1) 01-02-2024
https://community.jmp.com/t5/JMP-Wish-List/Additional-options-for-cross-hair-and-measurement-tool/id...
2) 3 weeks ago
https://community.jmp.com/t5/JMP-Wish-List/Crosshair-ability-to-snap-on-a-smoother-ed-curve/idi-p/71...
