UserID16644
How to multiply Y-Axis by 100?
I am currently using Variability Chart in JMP 15. And one of the requirement is to multiply its Y-Axis by 100. Is it possible to multiply the Y-Axis by 100? How to do it?
Re: How to multiply Y-Axis by 100?
Chance are your data percentages, and JMP is displaying them a .01, .02 etc. and you want them to be 1%, 2% etc?  If that is the case, just change the format for the column in the data table, to use the Percent format, and the values will be displayed as 1%, 2% etc.
markschahl
As always, Jim's (@txnelson) solution is a good one.
I just wanted to point out a little feature that a lot of JMP users don't know exists. Here's the JMP17 help, and should work in JMP15:
In Platform Column Transformation
Instead of analyzing the column directly, make a 100*column transform and analyze that.
Once I learned about this, I couldn't stop using it! Teaching this to other users always elicits the 'OMG, I didn't know you could do that!' response.
