How to move the labels inside the picture (see picture)? Thank you in advance!SUR_COMMUN.png
Hi Ted
No option in 'Red triangle' or somewhere in survival platform. My solution is add customer graph.
Sample data used 'Blenders', function 'survival'. Add JSL in customerize window.(See picture).
Hope it can help to solve your problem.
Attach JSL as below.
lineAuto_x=[9000 10000];
lineAuto_y=[0.95 0.95];
Pen Color("Red");Pen Size(2);
Drag Line( lineAuto_x, lineAuto_y );
lineM_x=[9000 10000];
lineM_y=[0.88 0.88];
Pen Color("Blue");Pen Size(2);
Drag Line( lineM_x, lineM_y );
Text( {10300, 0.93}, "Automatic" );
Text( {10300, 0.86}, "Manual" );
Make Legend floating:
and then you can drag and drop it
Edit: seems like you can just start drag and dropping without first changing the legend position.
Thanks, but my figure built here: Analyze->Realibility and Survival->Survival.
(Graph Builder does not build survival curves)
Hi Ted
