UserID16644
Level V
How to make combined data table from a specific plot?
Hi all, I have multiple bivariate plots and I am trying to get the Summary of Fit in one specific bivariate  plot (bivplot1). But I kept on getting every data from every bivariate plot.
How can I only get the summary of fit from a specific biv plot?
I am using these lines to get the summary of fit which is in bivplot1
sumfit = rbiv["Summary of Fit"][1] << make combined data table;
sumfit2 = sumfit << Split( Split By( :Column 1 ), Split( :Column 2 ) );
dt_sumfit =  Data Table Box( sumfit2 ) ;
dt_sumfit = dt_sumfit << get picture;
Re: How to make combined data table from a specific plot?
Make combined data table will get you results from each matching table box. Use Make into datatable with correct table box reference to get results from only one.
Here is example when getting the script from Source of datatable (this will create dublicated biv plot thou)
dt = Open("$SAMPLE_DATA/Drug.jmp");
biv = Bivariate(
	SendToByGroup(Bygroup Default),
	Y(:y),
	X(:x),
	Fit Line({Line Color({76, 114, 176})}),
	SendToByGroup({:Drug == "a"}, Fit Line({Line Color({221, 132, 82})})),
	By(:Drug)
//Source script, will dublicate biv platform
platform = Data Table("Drug=d") << Bivariate(
	Y(:y),
	X(:x),
Wait(0);
Report(platform)[Outline Box("Bivariate Fit of y By x Drug=d")][
Outline Box("Linear Fit")][Outline Box("Summary of Fit")][Table Box(1)] <<
Make Into Data Table;
Report(platform) << Close Window;
Or use Make Combined data table and then delete rows you don't want (this is simpler solution).
biv = Bivariate(
	Y(:y),
	X(:x),
	By(:Drug)
	Y(:y),
	X(:x),
Wait(0);
