rmthomas
How to make Dynamic Process Screening & Manage Spec Limits
Hello Everyone,
I am trying to build a dynamic work flow that will allow me to always save my spec limits using the manage spec limits and then using the process screening option. This work flow will have a different amount of columns each week. I tried to include all of the column names in and it worked until the next week where one or more of those columns are not there in the data table and it throws an error in both the manage spec limits and the process screening. Is there a dynamic way to always have the right name of the columns so that I will not get an JMP Alert each week?
Re: How to make Dynamic Process Screening & Manage Spec Limits
Yes,
The
<< get column names
message will return the names in a data table, and then you can create the column names list you need based upon what data are available.
See the Scripting Index for further details.
