Kwangki
How to insert multiple data without column name?
Below is JSL to make JMP table.
dt = New Table( "Floor Example",
     New Column( "Unit ID", Character, Nominal ),
     New Column( "Data1", Numeric, Continuous, Format( "Best", 12 ) ),
     New Column( "Data2", Numeric, Continuous, Format( "Best", 12 ) ),
     New Column( "Data3", Numeric, Continuous, Format( "Best", 12 ) ),
dtdata={
  {Unit ID = "A", Data1 = 1.1, Data2 = 2.1, Data3 = 3.1},
  {Unit ID = "B", Data1 = 1.2, Data2 = 2.2, Data3 = 3.2},
  {Unit ID = "C", Data1 = 1.3, Data2 = 2.3, Data3 = 3.3}
dt << Add Rows( dtdata );
I'd like to insert multiple data without defining column name as follows.
dtdata={
  {"A", 1.1, 2.1, 3.1},
  {"B", 1.2, 2.2, 3.2},
  {"C", 1.3, 2.3, 3.3}
Above is not right answer. Please let me know right JSL syntax.
gzmorgan0
Re: How to insert multiple data without column name?
Here are a couple of options that work with JMP 13 and higher.
dt << add rows(nitems(dtdata));
dtdata={
 For Each Row(dt, dt[row(),1::ncol(dt)]=dtdata[row()]);
 //or create a function to append
 addrows = function({listofrows, ctbl=current data table()}, {nr,nc, i},
 	nr = nrow(ctbl);
 	nc = ncol(ctbl);
 	for(i=1, i <= nitems(listofrows), i++,
 	  ctbl << add rows(1);
 	  ctbl[nr+i, 1::nc] = listofrows[i]
 ); //end function
 //add the rows again to demo this  function
 addrows(dtdata);
gzmorgan0
dtdata={
 	nr = nrow(ctbl);
 	nc = ncol(ctbl);
 ); //end function
 addrows(dtdata);
This situation is covered in the documentation. See Help > Books > Scripting Guide. There is a section about different ways to add rows to the data table. There are many examples throughout the guide. Here is the excerpt:
Add Rows
To add rows, send an Add Rows message and specify how many rows. You can also specify after which row to insert the new rows. The arguments can either be numbers or expressions that evaluate to numbers.
dt << Add Rows( 3 ); // add 3 rows to bottom of data table
dt << Add Rows( 3, 10 ); /* add 3 rows after the 10th row, moving the 11th and lower rows farther down */
A variation of Add Rows lets you specify an argument yielding a list of assignments.
Assignments can be separated with commas or semicolons.
dt << Add Rows(
{:name = "Peter", :age = 14, :sex = "M", :height = 61, :weight = 124}
or
dt << Add Rows(
{:name = "Peter"; :age = 14; :sex = "M"; :height = 61; :weight = 124}
You can send several arguments yielding lists, or even a list of lists. The following script
creates a data table with Add Rows commands of each variety:
dt = New Table( "Cities" );
dt << New Column( "xx", Numeric );
dt << New Column( "cc", Character, width( 12 ) );
dt << Add Rows( {xx = 12, cc = "Chicago"} ); // single list
dt << Add Rows( {xx = 13, cc = "New York"}, {xx = 14, cc = "Newark"} );
// several lists
dt << Add Rows(
{{xx = 15, cc = "San Francisco"}, {xx = Sqrt( 256 ), cc = "Oakland"}}
); // list of lists
a = {xx = 20, cc = "Miami"};
dt << Add Rows( a ); // evaluate as single list
b={{xx = 17, cc = "San Antonio"},{xx = 18, cc = "Houston"}, {xx = 19, cc =
"Dallas"}};
dt << Add Rows( b ); // evaluate as list of lists
