Neo
Neo
How to get the index of a particular value/entry in a list?
I have the following list, how do I get the index of SplPparameter?
myList = {paramter1, parameter2, parameter3, Splparameter, parameterN, parameterEnd};
Ans is 4  in the above example.
When it's too good to be true, it's neither
Re: How to get the index of a particular value/entry in a list?
Here are a couple of ways to handle your question.
// My solution when list items are expressions
For( i = 1, i <= N Items( mylist ), i++,
	If( myList[i] == Parse( "Splparameter" ),
		Break()
Show( i );
// If elements are strings the contains can be used
myList = {"paramter1", "parameter2", "parameter3", "Splparameter", "parameterN", "parameterEnd"};
i = Contains( myList, "Splparameter" );
//  Same using Loc() function
i = loc(mylist,"Splparameter" );
		Break()
Show( i );
ian_jmp
Level X
In the case of expressions, you can also use 'Loc()' (which returns a column vector):
myList = {paramter1, parameter2, parameter3, Splparameter, parameterN, parameterEnd, Splparameter};
Print(loc(mylist, Expr(Splparameter)));
If you know that the items are expressions, then this shorter code will work.
Contains( myList, Expr( Splparameter ) );
If not, then you need a more general code like the one provided by @txnelson
