How to get multiple overlay smoothers displayed
I am new to this community and thank you in advance to all the members for your help.
I tried to create a plot via Graph Builder with more than 1 variable, currently display as A & T smoothers. I would like to get 4 smoothers displayed, as A + 1-step; A + Osci; T +1-step; T + Osci instead. Basically adding pulling profile (A, T) into the overlay, together with Solvent.
Is it possible to do so?
shampton82
Re: How to get multiple overlay smoothers displayed
Hey @AdditiveLube66
You could concatenate the two columns (the one currently in overlay and the one currently in color) into a single one and then use that for the overlay.  That should give you 4 different smoother functions.
Steve
Which JMP version are you using and can you share small example data table so we know how your data looks like (sometimes you have to split/stack data first).
shampton82
Hey @AdditiveLube66
Steve
Works beautifully. Thank you very much for sharing.
