miguello
How to get a table (small) into a list of Associatives Arrays OR how to script column name inside "For Each Row"
Hi all!
I need to get a small table into a list of Associative Arrays. Where each row is a member of that list and is an Associative Array with column names as keys and row values as values.
Currently I have this:
listAA = {};
columnList = dt << Get Column Names( string );
For Each Row(
	currentAA = Associative Array();
	For Each( {columnName, index}, columnList, currentAA[columnName] = Column( dt, columnName ) );
	Insert Into( listAA, currentAA );
//Check
listAA[1]["age"]
listAA[1]["age"]
Column( "age" )
The output is not a value, but a reference to a column. So looks like it doesn't work when you refer to column using Column(name) inside For Each Row, only hardcoded names like in the Scripting Index:
For Each Row( :height = -:height );
Questions:
1. Is there a simple elegant way to get a list of AAs from a table? If not - how would I need to change my current version?
2. How to refer to a column not in a hardcoded way when using "For Each Row"?
Thanks,
M.
Re: How to get a table (small) into a list of Associatives Arrays OR how to script column name inside "For Each Row"
Maybe something like this
collist = dt << Get Column Names(string);
l = {}; For Each Row( aa = Associative Array(collist, dt[Row(), 0]); Insert Into(l, aa); ); Show(l);
You can also save it as .json and then parse it into AA
path = "$TEMP/test.json";
dt << Save(path);
json_str = Load Text File(path);
Delete File(path);
l = Parse JSON(json_str);
