Stokes
How to export RSquare from Bivariate Fit table use JSL and JMP
Hi, I am trying to export the Bivariate Fit summary table using below jsl,
however, it doesn't include the RSquare value, only the linear fit equations.
Can someone help how to extract the RSquare data?
Thanks
rbiv = biv[1] << Report;
Rt1 = rbiv["Parameter Estimates"][Table Box( 1 )] << Make Combined Data Table;
Re: How to export RSquare from Bivariate Fit table use JSL and JMP
The R2 statistics are not in the Parameter Estimates paragraph that you are pointing at.
They are in the Summary of Fit paragraph and what you need to do is to apply the Make Combined Data Table message to the table box in that paragraph
Rt1 = rbiv["Summary of Fit"][Table Box( 1 )] << Make Combined Data Table;
Stokes
Great, thanks for the help.
