How to dynamically update process screening or other objects.
Hello again JMP community,
Thanks a lot for taking your time and answer my previous question. The code that I run below (JMP pro 17.2) doesn't seem to work as intended. My goal is after I press the Redo button, the Process Screening changes from grouping by "lot_id" to grouping by "wafer".
I guess that once I declare the PS variable it keeps all the initial settings and it is not possible to dynammically update it as I could not find any "<< " command that would update the Grouping variable. Is there a simple solution for this example:
Cols = {"NPN1", "PNP1", "PNP2", "NPN2"};
GR = "lot_id";
dt = Open( "$SAMPLE_DATA/Semiconductor Capability.jmp" );
PLAT = Platform(
	dt,
	PS = Process Screening(
		Y( Eval( Cols ) ),
		Grouping( Eval( GR ) ),
		Control Chart Type( "Indiv and MR" ),
		Minimum Process Length( 1 ),
		Use Medians instead of Means( 1 ),
		Show tests( 0 ),
		Test 1( 0 ),
		Cp( 1 ),
		Spec Limits( 1 ),
Redo= Expr(
			GR = "wafer";
			NW << Close Window;
			PS << Redo Analysis;
			Make_Win();
Make_Win = Expr(
	NW = New Window( "ProcessScreening",
		Vlist_box = V List Box(
		PLAT,
		BB = Button Box( "Redo", Redo ),
Make_Win();
Best regards,
NJS.
Re: How to dynamically update process screening or other objects.
This might give some ideas what you could do
GR = "lot_id";
ps = Expr(dt << Process Screening(
	Y(Eval(Cols)),
	Grouping(Eval(GR)),
	Control Chart Type("Indiv and MR"),
	Minimum Process Length(1),
	Use Medians instead of Means(1),
	Show tests(0),
	Test 1(0),
	Cp(1),
	Spec Limits(1)
redo_ps = Expr(
	If(GR == "lot_id",
		GR = "wafer";
		GR = "lot_id";
	ps_collector << Delete Box();
	vlb << Append(ps_collector = V List Box(ps));
nw = New Window("ProcessScreening",
	V List Box(
		vlb = V List Box(
		BB = Button Box("Redo", redo_ps);
GR = "lot_id";
	Y(Eval(Cols)),
	Grouping(Eval(GR)),
	Show tests(0),
	Test 1(0),
	Cp(1),
	Spec Limits(1)
redo_ps = Expr(
	If(GR == "lot_id",
		GR = "wafer";
		GR = "lot_id";
	V List Box(
		vlb = V List Box(
