s22d704
How to display the cutoff value on the ROC curve.
Is there a way to display the cutoff value on the ROC curve with a dot and a number? Please provide a reference example.図1.png
Victor_G
Re: How to display the cutoff value on the ROC curve.
Hi @s22d704,
You can use the Crosshair tool '"+" symbol) on any graph to display individual X-Y values :
More infos about the tools in JMP :The Tools Menu - JMP User Community
For binary classification models, you can also have a look at Decision Thresholds Report which may help you to assess the impact of the decision threshold value on specificity, sensitivity, precision, accuracy, F1-score, Matthews Correlation Coefficient, ... :
Hope this answer may help you,
Victor GUILLER
Victor_G
Hi @s22d704,
Victor GUILLER
