LipYeong
How to delimit multiple column with specific string in jsl
I've a table that would like to delimit multiple column with specific string
Script below able to point to the specific column but unable to delimit the data
Appreciate if anyone could help on this. Thanks
dt = Data Table( "Sales");
headerList = dt << get column names( string );
For( i = 1, i <= N Items( headerList ), i++,
	If(  Contains(headerList[i], "sales"),
		Column( dt, headerList[i] ) << text to columns( delimiter( "_" ));
pauldeen
Re: How to delimit multiple column with specific string in jsl
You have to send that command to the table not the column. When you do, it inserts extra columns to the right so going left to right is going to break things. You need to go right to left (i-- instead of i++) This works:
For( i = N Items( headerList ), i>=1, i--,
	Data Table( "Sales" ) << Text to Columns(
		columns( Column(dt, i) ),
		Delimiters( "_" )
pauldeen
		Delimiters( "_" )
LipYeong
Thanks Paul, this solution works. I've added the for loop into the if condition statement and it solved the issues.
dt = Data Table( "MTL");
	If(  Contains(headerList[i], "CLASSHOT 1"),
	dt << Text to Columns(columns( Column(dt, i) ),Delimiters( "_" ));
