abdulj
How to create variable names depending on loop number
Hello
I am trying to create variables dynamically depending on the number of times my loop runs. How can I go about doing this?
Example
for(i=1, i<x, i++,
     //some code goes here
     var || i = current data table();   //This obviously does not work, but I hope you get the idea. I would eventually like to have var1, var2, var3, etc... till the loop is done
Does this make sense?
thanks
michaelhaslam_p
Re: How to create variable names depending on loop number
Abdulj,
Here is one way using Eval ( Substitute ( ))
// dv = dummy variable
x = 10;
For( i = 1, i <= x, i++,
	Eval(
		Substitute(
				Expr(
					dv_variable = i;
					Show( dv_variable );
			Expr( dv_variable ), Parse( "Variable Name " || Char( i ) )
Michael
8 REPLIES 8
michaelhaslam_p
Abdulj,
x = 10;
	Eval(
		Substitute(
				Expr(
					dv_variable = i;
Michael
Byron_JMP
Wasn't there a talk on this at the Advanced Scripting Panel discussion at the JMP Discovery conference Last week? It was a great seminar, I wonder if the author posted any notes on his talk.
David_Burnham
Here is an alternate notation:
	Eval( Parse( Eval Insert( "\[
        var^i^ = Current Data Table()
-Dave
-Dave
Dave,
I've never seen that syntax before, do the ^ surround any variable to include in text?  I would have written:
tmp = "var" || char(i) || " = Current Data Table()";
eval(parse(tmp))
This is obviously less efficient than what you've written.
David_Burnham
Yes enclose each variable with ^ ... ^ and have the jsl statement enclosed in the Eval( Parse( Eval Insert("\[ ...  ]\"))) pattern.
For example, the following code sets spec limits for a column:
Open("$SAMPLE_DATA/Big Class.jmp");
cHeight = Column("height");
Column("height") << Set Property( "Spec Limits", {LSL(55), USL(75), Target(65)} );
Let's say we have the following variable assignments that we would like to use:
colName = "height";
lower = 55;
upper = 75;
target = 40;
Then we can write:
  Column("^colName^") << Set Property( "Spec Limits", {LSL(^lower^), USL(^upper^), Target(^target^)} );
-Dave
-Dave
abdulj
thanks guys!
KinKame
oh nice .... thank you very much. Another thing I need to learn in JMP ...
Why create a new variable for each reference? Why not store the data table reference in a list for access by index or an associative array for access by key?
