Try the Materials Informatics Toolkit, which is designed to easily handle SMILES data. This and other helpful add-ins are available in the JMP® Marketplace
Neo
Neo
How to create a two column user input modal window where the second column is populated based on single input on first column?
I would like to create a two column user input modal window where the user input goes into the first column (single input box) for a "parent part ID", based on which adjacent second column window entries (child part IDs) get populated.
  • The entries in the second column come from a database query (for which I already have a script). A "parent part ID" can have one or more than one "child part IDs"
  • This query script needs to run upon a checkbox being checked adjacent to the parent part ID input box after the input.
  • Once one or more than one child part IDs (as the case may be) are selected in the second column (again using checkbox), press of the OK button at the bottom of the modal window is to make the selected entries in second column available (as a list) for a follow on script to use.
  • A select all option for the entries in the second column would be an added advantage.
I would appreciate if I can get some ideas on how to proceed with this in JSL?
When it's too good to be true, it's neither
21 REPLIES 21
Neo
Neo
Re: How to create a two column user input modal window where the second column is populated based on single input on first column?
@jthi My JMP skills are not good yet (I have been a Matlab user so far) so still struggle with the JMP way of thinking. I am trying this side but so far no success. Never used this before.
What I was trying was use Get Selected Indices (), something I have used before, to capture user click on Get Child IDs, based on which get the function call to fire and get the Child IDs. Again no success so far.
Neo
Neo
@jthi . I seem to have made some progress, but still need help.
I have moved back to script (in place of function in post 5 in this thread).
Below is partly working script. I am struggling to input the Parent ID (e.g. "715" below) from users Parent ID input in my fetchChildIds function. Need help here.
I basically need to get the input to the text edit box into my function argument to replace "715".
Names Default To Here (1);
clear log ();
include ("_fetchChildIds.jsl");
//aa_parents << Set Default Value({});
get_childids = function({this}, {Default Local},
	//new_childids = aa_parents[(this << prev sib) << get text];
	new_childids = fetchChildIds ("715");
	lb_child << Set items(new_childids);
nw = New Window("",
	H List Box(
		Panel Box("[1] Enter Parent ID", //sets outside panel
			Lineup Box(N Col(2),
			pid = Text Edit Box("", << Set Width(150)),
				Button Box("Get Child ID(s)", << set function(function({this},
					get_childids(this);
		Panel Box("[2] Select Child ID",
			H List Box(
				lb_child = List Box({}),
				Lineup Box(N Col(1),
					Button Box("Select All",
						For Each({item, idx}, lb_child << get items,
							lb_child << Set Selected(idx);
						wait(0);
					Button Box("Unselect All",
						lb_child << Clear selection;
		Panel Box("[3] Fetch Test Data",
				Button Box("OK"),
				Button Box("Cancel")
Neo
Neo
@jthi
Why does this not show the user entered parent ID. It proceeds with 715. An updated value is not taken/used. Am I placing in the wrong place i.e. under the Text Edit Box?
pid = Text Edit Box("715", << Set Width(150)),
			ParentID = nw["pid" ];	show (ParentID);
the user updated ParentID is available outside the New Window (), but iI think I need it when the Button Box is pressed.
					get_childids(this);
You need to use << Get Text to get the value from Text Edit Box
Neo
Neo
@jthi  yes, tried << Get Text. I can get the value out ouside the new window()
I think my issue is correct placement of the Get Text.
I cannot get the Parent ID from user input to pass on correctly when "Get Child ID" button is placed.
Pressing "Get Child ID" should run my fetch Child ID function with the Parent ID from user input.
Would appreciate some help here.
You are using hard-coded input value of "715" and not the user's input
Neo
Neo
@jthi
This was just to show what I am doing. I want to replace "715" with user input.
The Parent ID needs to pass to the function argument when the Get Child IDs botton is pressed.
fetchChildIds ()
 The hard coded case works as expected, but I cannot get the user input in as an argument to my above mentioned function.
The script has no indications of you using for example
pid  << get text
my method of using of using this to travel display boxes is more complicated (but sometimes might be more robust), just using reference should be enough.
Also start with very simple script and get it working first. Start with scripting index example:
win = New Window("Example", fontobj = text = Text Edit Box("Example Text"));
Print(text << Get Text());
modify it to have button box
	teb = Text Edit Box("Example Text"),
	Button Box("Get Text")
add function/expression to the button
	Button Box("Get Text",
		show(teb << get text)
move the function/expression out of button box
get_my_text = function({}, {Default Local},
		get_my_text();
make the function return something
	teb_txt = teb << get text;
	return(teb_txt);
		user_txt = get_my_text();
		show(user_txt);
and so on. It is very difficult to try and get the whole script working on one go, so work on much smaller problems one at the time
Neo
Neo
@jthi Many thanks for your inputs. I have now made the script much smaller which I hope will help highlight the issue I am having.
My comment in capital case below (adjacent to returnedPid = pid << get text; show (returnedPid)) is where I need help.
The user input on Parent ID is not getting passed onto get_childids function call.  Is my <<get text misplaced (it is reporting the default value "" and not the user updated value)?
// function inclusion to fetch child IDs from data base for a given Parent ID.
include ("_fetchChildIds.jsl"); // function called below.
	new_childids = fetchChildIds (returnedPid);
	//lb_child << Set items(new_childids);
nw = New Window("FetchData ", //<< Modal, <<Return Result,
	H List Box(
			pid = Text Edit Box("", << Set Width(150)),	// defines the user input box
			returnedPid = pid << get text;	show (returnedPid); //DOES NOT GET/SHOW USER INPUT
					get_childids(this);
		Panel Box("Fetch Test Data",
				Button Box("OK"),
It should be inside the button box, not somewhere in between text edit box and button box.
	H List Box(
				pid = Text Edit Box("", <<Set Width(150)),
					Show(returnedPid); // does get user input
				Button Box("OK"),
