  • See how to import and prepare Excel data. Jan. 30, 2-3 pm US ET. Register.
Neo
Neo
How to count number of rows generated by Tabulate()?
I have a JSL of the form below to generate a table using Tabulate (). How do I count the number of rows in the table?
Note the number of rows change with what I have got selected in the Local Data Filter () and the row count needs to be updated with my filter selection.
Tabulate(
	Add Table(
		Column Table( Grouping Columns( :Parameter1 ) ),
		Row Table( Grouping Columns( :Wafer ) )
	Local Data Filter(
		Conditional,
		Add Filter(
		// my filter selection goes here
When it's too good to be true, it's neither
hogi
Level XIII
Re: How to count number of rows generated by Tabulate()?
you could use make into data table
table = dt << Tabulate( Add Table( Row Table( Grouping Columns( :sex ) ) ) );
tabulateTable = table << Make Into Data Table;
count = N Rows( tabulateTable );
Close( tabulateTable, noSave );
count
Neo
Neo
@hogi  Thanks, but the count would not dynamically change when the data filter selection is changed, would it?
hogi
Level XIII
You can add a button to the window - and click to calculate the rows.
Or automatically calculate the number, triggered by a state handler of the data filter.
