saitcopuroglu
How to convert character formats to date format
Dear All,
I receive data in excel with Date columns in various format (defined as character)
31.02.2015
31.2.2015
Feb 31 2015
and many more..
Trying in excel to format them but does not work for excel import wizard (mac)
How will I convert them to one valid Date Column in JMP?
Thank you in advance for your support.
11 REPLIES 11
Re: How to convert character formats to date format
No, not out of turn at all... My VBA is just really weak  ... sticking to my strengths here!
SDF1
Hi @MikeD_Anderson,
  I was having a similar issue as the original post did, but more with converting a date format from German style: dd.mm.yyyy to mm/dd/yyyy.
  I tried the InFormat() approach, but it didn't work, whereas the formula in your date example data table worked perfectly! So, I would also mark yours as a correct solution, even though it's not as elegant.
Thanks!,
DS
