Alex19
How to convert Julian Date (YYDDD) to Calendar Date *ddMonyyyy"?
Hello community,
I think I exhausted all my options, even AI does not give me the correct answer.
I have a column with multiple Julian Dates - hundreds of them (e.g. 23233 etc.) and need to have a column with calendar date. Let's name Julian date column as "Julian Date".
Either formula in the column or a script would be good!
Thank you ALL!
Alex.
Re: How to convert Julian Date (YYDDD) to Calendar Date *ddMonyyyy"?
Here is my way of handing this
dt = New Table( "Example",
	add rows( 10 ),
	New Column( "Julian Date",
		set each value(
			Num(
				Char( Random Integer( 20, 24 ) ) || Char( Random Integer( 100, 365 ) )
// Create a column that converts Julian dates to JMP date values
dt << New Column( "Date",
	Format( "m/d/y" ),
	formula(
		Date MDY( 1, 1, Num( Substr( Char( :Julian Date ), 1, 2 ) ) )
		+In Days( Num( Substr( Char( :Julian Date ), 3, 3 ) ) )
	add rows( 10 ),
		set each value(
			Num(
	Format( "m/d/y" ),
	formula(
Alex19
Works very well! Thank you Jim!!
Alex.
