mystylelife19
How to convert 24 Hour into 12 Hour with AM/PM?
Hi Community,
I have data table with column TimeStamp 2023_10_04 02:22:24. Right now i already split the date & time into separate column using this script below:
dt = Current Data Table();
dt << Text To Columns( delimiter( " " ), columns( :TimeStamp ) ); // in delimiter is SPACE
// Close the original timestamp column
dt << Delete Columns( "TimeStamp" );
dt << Delete Columns( "TimeStamp 1" );
But the format column still in 24 hour
I want format 12 hour like this
The problem is i have to use text to columns in excel if i want format 12 hour.
Can you please write me a script that can change all the row in columns into 12 hour format?
Craige_Hales
Re: How to convert 24 Hour into 12 Hour with AM/PM?
You might want to back up and not split the character data at all, just convert the original character time stamps into JMP date-time values.
(view in My Videos)
Craige
9 REPLIES 9
You could try using Format Pattern to create correct format for you. You can find it from column properties
mystylelife19
Hi jthi,
I try to change into format 12 in column properties
Turns out my time change into dot
Please help,
Try out the different options that Format Pattern provides you with (it has explanation what each different option does).
Craige_Hales
(view in My Videos)
Craige
Craige_Hales
JMP's date-time values are numbers of seconds. The format determines how the number is displayed, but does not change the underlying numeric data stored in the data table.
Craige
Craige_Hales
The timestamp2 column contained character data before conversion. You'll need to convert it to numeric date-time data first by choosing both numeric and the proper format at the same time from the dialog. After that, you can change the format to have am/pm.
Craige
Craige_Hales
(view in My Videos)
Craige
mmarchandTSI
Level V
That will happen if your current column is character and you try to directly change to numeric with your output format pattern.  First, change the data type to numeric and apply the change.  All the values should become large whole numbers.  Then, set the format pattern as you did before.
mystylelife19
Thankyou all, got it right now.
Best Regards,
mystylelife19
