Quenton
How to compare among multiple survey responses? That is, each survey respondent scores multiple factors to be compared.
I have survey responses from the following question: "Seagrass loss can be attributed to what factors?" There are multiple factors which can be scored from 1-5. Thus, each survey respondent will give a number for each factor. I want to identify the factor that respondents indicate is most associated with seagrass loss.
I was thinking of just treating the scores as continuous, with the DV being score, IV being the factor, and the respondent as a random effect in a mixed model.
Re: How to compare among multiple survey responses? That is, each survey respondent scores multiple factors to be compared.
Hi @Quenton ,
Can you provide an example data set for this?
Here's some resources that might help: https://www.youtube.com/watch?v=72EZ8k3LjA8
https://community.jmp.com/t5/Abstracts/Conducting-Survey-Data-Analysis-Using-the-JMP-Fit-Model-Platf...
Thanks,
Ben
