LipYeong
How to combined data table from multiple bivariate plot fit model using JSL
I've a multiple bivariate plot and would like to make all group fit model summary into data table.
Script is working when it's pointing to one group but not working when point to multiple group
Appreciate if anyone could help on this. Thanks
Script able to output data table for one group
dt = Data Table( "ReportSummary" );
biv = dt << Bivariate(
	Y( :Reference_A  ),
	X( :Reference_B ),
	Fit Line( {Line Color( {212, 73, 88} )} ),
	Fit Special(
		Intercept( 0 ),
		Slope( 1 ),
		Centered Polynomial( 0 ),
		{Line Color( {61, 174, 70} )}
    	Where( :Label == "FrequencyA" )
reportbiv = biv << Report;
dt = reportbiv["Summary of Fit"][1] << make combined data table;
No output data table while pointing to multiple group
	Y( :Reference_A  ),
	X( :Reference_B ),
	Fit Special(
		Intercept( 0 ),
		Slope( 1 ),
   	By( :Label ) /*Contained multiple group*/
Re: How to combined data table from multiple bivariate plot fit model using JSL
The Bivariate report produces a separate output object for each level of the By group.  Therefore, the reference to each level of the report structure is required.  If you change your JSL to the below, it will point to the 1st of the multi level report structures and  generate the output data table
reportbiv = biv[1] << Report;
