MicroSheep
How to combine and export plots from the terminal (Windows) or a jmp script?
Hello everyone,
I'm trying to combine a bunch of plots into a dashboard and later export that dashboard into an html file. Currently I modify a template.jmp using python and later execute the file using
    subprocess.call([r'C:\Program Files\SAS\JMP\16\jmp.exe',r'outputScript.jsl'])
My problem is that I'm unable to build the dashboard and export the result as an html file. I think I could add code to generate the dashboard in the template.jmp or use some jmp.exe --ObscurePerfectInstruction but need some assistance. Thanks for the help!
Re: How to combine and export plots from the terminal (Windows) or a jmp script?
Can you provide more information? Is it:
  1. You don't know how to build the dashboard in JSL,
    1. Here's a link to an overview
  2. You don't know how to use JSL to output an html file, or
    1. obj << Save HTML() is what you're looking for (link here)
  3. something else?
    1. I get the feeling it's this category of help you're looking for. Any extra info you can provide should be helpful.
