saitcopuroglu
How to choose/activate open but not saved data tables back and forth
During automated report script I create many summary tables which I don't save. Since the last created table is active and any -let's say Graph Builder- graph will be produced from the last produced active table, how do I activate/choose an inactive but open data table?
A simple example is:
dt1 = Open( "$SAMPLE_DATA/Big Class.jmp" );
dt2 = Open(
  "$SAMPLE_DATA/Fitness.jmp",
  Select Columns( "Name", "Sex", "Age", "Weight" )
Graph Builder(
  Title Fill Color( "Light Blue" ),
  Title Frame Color( "Medium Dark Gray" ),
  Level Fill Color( {174, 203, 228} ),
  Level Frame Color( "Medium Dark Gray" ),
  Level Underline( 1 ),
  Variables( X( :Sex ), Y( :Weight ) ),
  Elements(
  Bar(
  X,
  Y,
  Legend( 2 ),
  Bar Style( "Side by side" ),
  Summary Statistic( "Mean" ),
  Label( "Value" )
I would like to keep graphing but with the Big Class Data Table where the Fitness data table is active/chosen...
Thank you in advance for your help
Craige_Hales
Re: How to choose/activate open but not saved data tables back and forth
dt1<<graph builder(...)
if you don't specify a table, the "current" table is used.  You should always specify a table since the current table changes when you click on a different table or open another table.
<< is the operator to send a message to an object.  A data table is an object, and it understands messages that look like launching platforms.
Craige
Craige_Hales
Craige
pmroz
You can also explicitly set the current data table using current data table(tbl_variable):
dt2 = Open(
current data table(dt1);
Graph Builder(
     Elements(
           Bar(
                X,
                Y,
                Legend( 2 ),
                Label( "Value" )
