mystylelife19
How to change value in specific columns using scripts
Hello community, i'm new to this JMP. Asking for help for those who know on how to change all value in 1 columns?
I already make the script to rename the columns but how to change also on value depend on text box?
:WAFER_ID << Set Name( "PROBE" );
User_Input = New Window( "JMP AUTOMATION", << modal(),
	hlistbox(
		Text Box( "Enter Probe ID:" ),
		ID_Probe = Text Edit Box( "", <<set width( 200 ) ),
	Button Box( "OK",
		ID_Probe = ID_Probe << get text();
Re: How to change value in specific columns using scripts
Here is one way to do it
	<<modal(),
	H List Box( Text Box( "Enter Probe ID:" ), ID_Probe = Text Edit Box( "", <<set width( 200 ) ), ),
	Button Box( "OK",
		ID_ProbeVal = ID_Probe << get text();
		If( ID_ProbeVal != "",
			Current Data Table():Probe << set each value( ID_ProbeVal )
	<<modal(),
	Button Box( "OK",
mystylelife19
OMG, thanks so much sir. It works :)
