lala
Level IX
How to automatically write code containing /**/ to JSL?
For example, I use the following JSL to automatically generate a table script file in a data table.
But how to write the code containing /**/ into the script file of this table?
Thanks!
dt=Open("$SAMPLE_DATA/Big Class.jmp");
Eval(Parse("dt<<new script(\!"test\!",  dt<<Select Where(age==12);d3=dt<<Subset(Output Table(\!"age12\!"),Selected Rows(1),selected columns(0));try(d3<<Delete Table Property(\!"Source\!"));  );"));
  • For example, insert code like /**/
Eval(
	Parse(
		"dt<<new script(\!"test\!",  dt<<Select Where(age==12);d3=dt<<Subset(Output Table(\!"age12\!"),Selected Rows(1),selected columns(0));try(d3<<Delete Table Property(\!"Source\!")); /*d3<<Sort(By( height ),Order(Descending),replace table);*/ );"
lala
Level IX
Re: How to automatically write code containing /**/ to JSL?
Achieve the effect
I'm not sure if this is directly possible, but you can use workaround combining Eval(Parse(JSL Quote)))
dt << New Script("Test",
	Eval(Parse(JSL Quote(
			Current Data Table() << Sort By(:height);
		show(1);
How to keep formatting and comments with New Script () ?
Preserve comments and whitespace in JSL code attached to data table
lala
Level IX
Thanks!
Looks like it has to be this way
