Kenobi
How to append graph builder plots in a report or a journal?
I just started working with this language 3 days back. I am working on a script that automates the creation of plots based on certain specifications in the Graph Builder. The step I am stuck on, is to integrate all plots in a report or journal, in order for easy understanding.
// x_col and y_cols contain the selected columns for which graphs have to be plotted. x_col is singular
x_col = dlg["xList"];
y_cols = dlg["yList"];
// Iterate over the Y columns and create a Graph Builder plot for each
For(i = 1, i <= N Items(y_cols), i++,
            gb = dt << Graph Builder(
                Size(534, 456),
                Show Control Panel(0),
                Variables(X(x_col[1]), Y(y_cols[i])),
                Elements(Points(X, Y, Legend(7))),
                invisible
            gb << Save Picture("Plot_" || Char(i) || ".emf", EMF);
I am able to save the plots as an image, but the requirement is to get images in a folder and the report/journal. Any help would be appreciated.
Thank you!
Kenobi
Re: How to append graph builder plots in a report or a journal?
Hi, I think I got it solved now. Sharing the script with you all, in case any one else encounters the same issue
nw = New Window( "graphs", myVLB = V List Box() );
				Size(534, 456),
				invisible
			myVLB << append( Report( gb ) );
			gb << delete;
Kenobi
				Size(534, 456),
				invisible
			gb << delete;
