Elby
How to add New Rows in Conditional Match jmp 15
Is it possible to automatically add new matches to the formula?
My data contains a Conditional Match Formula to group data.
I.E. the data includes Rows like PartA-V1, PartA-V2, PartA-V3 and PartB-V1, PartB-V2, PartB-V3 that the matches would be PartA or PartB since the -V does not change what I am looking for.  The actual data is has more complicated descriptions.  The original data had ≈50 Matches so recreating the entire match table/formula is not easy.
The issue is - when new data, PartA-V4, PartC-V1, they are not included in the prior match functions.
Thank you for any assistance.
Georg
Re: How to add New Rows in Conditional Match jmp 15
If I understand correctly, you need a more general formula to group your data.
I would use e.g. "words" if the string has always a "-" and you need the first part, like follows:
Words("PartA-V1", "-")[1]
Georg
