wmwinn
How to Delete external files? - scripting in JSL
Is there a way to Delete files from within the JSL scripting?  Looking for a DELETE command or something like that.
For example:
myfiles = Files In Directory("pathname")         => provides a list of all files in the pathname, and I would like to delete one or more of those files in the list.
Anybody know how to do this?  Thanks,
- Mark -
gbu
gbu
Re: How to Delete external files? - scripting in JSL
If you're using an earlier release than jmp10 (for windows), you can in your script create a .bat file and also call this .bat to delete files.
/* Create a .bat file command with delete instruction */
Save Text File("C:\deletemyfile.bat","del C:\myfolder\myfile.txt");
/* Execute the .bat file in order to delete the file */
Open("C:\deletemyfile.bat");
mattflynn
from the JMP 10.01 /Help, Scripting Index, Utility functions:
see:
     Copy File()
     File Exists()
     Delete File()
functions
Best,
-Matt
gbu
gbu
wmwinn
Thank you, gbu.  Since I'm running JMP v9, that's exactly what I did.  It's working GREAT.
Question ANSWERED.
