NishaKumar
How do you calculate the PR Curve in JMP's addin XGBOOST?
I am needing to determine the PR Curve for XGBOOST (addin in JMP Pro), is there a way to ask JMP to output it? Otherwise, would the calculation:
the number of true positives divided by the total number of true positives and false positives suffice in manually calculating the PR Curve?
Re: How do you calculate the PR Curve in JMP's addin XGBOOST?
It does seem to get added to the platform based on (column?) inputs
obj = XGBoost(Y(:age), X(:height, :weight), Fit);
