joelahn
How do we add a whitespace within the string in one of lists of which specific character length bigger than standard form?
For an example;
Character Column#1 at row#1: asd 123 deg jkldjsakldjlk 1124
if length of any of word within the cell value is bigger than "5", I want a whitespace on the third character.
Ideal form is as below
Character Column#1 at row#1: asd 123 deg jkl djsakldjlk 1124
thanks,
Joel Ahn
Lam Research Corporation
Mobile +82 10 9509 0109
Re: How do we add a whitespace within the string in one of lists of which specific character length bigger than standard form?
One way would be to use Regex.
This might work:
line = "asd 123 deg jkldjsakldjlk 1124";
span_line = Regex(line, "([a-zA-Z0-9]{3})([a-zA-Z0-9]{3,})", "\1 \2", GLOBALREPLACE);
show(span_line == "asd 123 deg jkl djsakldjlk 1124");
line = "1 22 333 4444 55555 666666 7777777 88888888 999999999 0000000000";
show(span_line);
https://regex101.com/r/CuxFKx/1
Here is one way of doing what you want
dt = Current Data Table();
For Each Row(
	holdString = "";
	wordNum = 1;
	While( Word( wordNum, :column 1, " " ) != "",
		theWord = Word( wordNum, :column 1, " " );
		If( Length( theWord ) > 5,
			theWord = Substr( theWord, 1, 3 ) || " " || Substr( theWord, 4 )
		holdString = holdString || " " || theWord;
		wordNum++;
	:Column 1 = Trim( holdString );
I am not sure if you an interactive, a formula, or a scripted solution. The Cols > Recode command provides a rich tool for changing values in a column. See examples and instructions for Recode here.
